Old 03-09-2009, 08:57 PM   #1
jbracecraft
Default lots of schtuff for sale
laydown freezer used for carbon $100
(2) 50? yard rolls of carbon pre preg $300 for both
cotton, resin, 5 gal of black gelcoat etc... $500
22"x22"x48" oven with real nice timer control $300
(2) 10'x5' wooden tables used for layout $125 each or $200 for both
mustang 8.8 rear 3.55, disc brakes $200
murf mk2020p jig chassis for mounting funny car bodies $400
murf mk2020p steel motorplate $200
murf aluminum bellhousing shroud $200
-buy all three items for $600
tubing grinder $500
dragster backhalf engine cart $100
used dragster radiator $100
small block chevy alumium front plate 36x12 not cut $75
12" electric fan $40
angelle snap on clock $50
hadman chute tubes $25 per set (rh, lh)
lift block fixture for mini truck (dihatsu, suzuki and mitsubishi) $50 for each or $100 for all three
jbrc four link brackets: fronts $150 per set (4 sets) rears $150 per set (2 sets)
dragster jig table cncd $3750 or $6000 with fixtures
16ft jig table cncd $2000 or $2500
8' sheet metal brake w/ 2 radius dies $1900
52" stomp shear $900
36" bead roller w/ 4 dies $700
strange alum 3rd member 40 spline, spool etc... new $1300
strange dual caliper brakes, new style with floating rotor $1000
sony surround stereo, 5 disc changer, (2) bose bookshelf speakers $600
4x8 wooden table, carpeted w/ shelf used for tin $125
sheet metal rack, 5 slots for mtl, shelf, and upper shelf that will store two dragsters or door car if needed 8' off ground $500
pallet racking, 28'x5'X20' high 6 sets of shelves $500
10" cold saw with steel cutting tables on each side $1350
ingersol rand 10hp 120 gal 3ph air compressor, 2 yrs old $2500
10'x10' overhead crane, casters, 1 ton trolley etc $750
(3) jbrc style carbon bonnets $250 each
(9) '68 camaro carbon chin spoilers $175 each
(3) 48"x144" .040 5052 aluminum sheet, new with plastic $150 each
glass corner display case, nice condition w/ light $250
sprint blackberry 8550 world edition $100
sprint palm 700w $100
tubing rack for wall $250
(20+) 24' lengths of 2-1/2 x 3/4 bar stock mild steel $50 each or $500 for all
buyer pays all shipping or picks up themselves. we have access to a forklift if needed. if pics are needed please send email address. thank you.
joey b
317-645-8786
joeyb@jbracecraft.com
jbracecraft is offline   Reply With Quote
