Old 03-04-2009, 04:34 PM   #1
robemlikian
robemlikian's Avatar
Question Oil Filters
Is It better to use an oil filter with or without an anti-drain back valve? What exactly does this valve do and how does it work?Specs on both filters were the same except,one had the valve and the other did not.Wix #51060R/51061R
robemlikian #190
robemlikian is offline   Reply With Quote
Old 03-05-2009, 01:23 PM   #2
Ken Haase
Default Re: Oil Filters
Generally speaking, an anti-drainback filter would only be necessary when the filter is mounted horizontally or where the oil could exit the filter when the engine isn't running. Applications like Chevy's and other vertical mounts shouldn't require the valve in the filter.
Ken Haase is offline   Reply With Quote
Old 03-17-2009, 02:22 PM   #3
Bryan Gillespie
Banned
Use Fram HP 4 if chevy
Bryan Gillespie is offline   Reply With Quote
