Old 02-15-2009, 11:36 AM   #1
T Hall
T Hall's Avatar
Default 434 Roller motor complete
434 , compltete RACE ROLLER motor.
GM block with splayed caps. Filled. New 77H race bearings (Rod and Mains). EAGLE 4340 Crankshaft. LUNATI PRO MOD RODS. JE 13.1 pistons. New TOTAL SEAL MAX SEAL Rings. 7 qt MOROSO pan with windage tray. CANTON aluminum reusable oil filter. ATI SUPER DAMPER.
AIR FLOW RESEARCH 227 factory ported aluminum heads with 2.1.intake, 1.65 ex. New roller springs and guides. AIR FLOW RESEARCH Stud gurdle.LUNATI Roller cam. .656 in. .668 ex. Lunati roller lifters. COMP CAMS PRO MAGNUM rockers.
EDELBROCK Victor intake. MSD Crank trigger distributor and MSD wires.
SFI flexplate.
Motor is primed and ready to go. MUST SELL $6500. WILL SEPERATE TOP AND BOTTOM END.
Tony 614-599-6546
Tony Hall
3545 S/ST
T Hall is offline   Reply With Quote
