Old 05-30-2007, 10:15 PM   #1
Sarg Snafo
Default BOGUS COMBINATIONS & NO CLASS RACERS RUIN CLASS RACING
HEY!!!!!!!!!! DO I HAVE YOUR ATTENTION ?
HOW WOULD YOU LIKE TO GO 2. SECONDS UNDER IN SUPER STOCK?
THE MOST BOGUS COMBO THERE IS...............
WANT TO MAKE PEOPLE THINK YOU'RE SMART WHEN YOU DON'T KNOW YOUR *** FROM A HOLE IN THE GROUND?
IF YOU ANSWERED YES THEN PUT A 1985 350 OLDSMOBILE F.I. ENGINE THAT CAME IN A CADDILAC SEVILLE IN A SS/GT CAR.
THIS COMBO IS RATED @ SOMETHING LIKE130 HP , WHEN IT SHOULD BE RATED @ 300+ HP. GUESS IT SLIPPED BY NHRA. I KNOW WHAT YOU ARE THINKING, WOULD SOMEONE TRY TO RUN THAT AND GET AWAY WITH IT, YOU WOULD HAVE TO RUN THE CAR 800 LBS. HEAVY!!! BOB DENNIS KNEW ABOUT THIS COMBO YEARS AGO BUT PEOPLE LIKE HIM HAVE RESPECT FOR CLASS RACING AND WOULD NOT RUN SUCH A BOGUS COMBO AND SANDBAG ALMOST 1 SECOND TO KEEP FROM GETTING HP. ENTER KEVIN MURPHY A.K.A. ROCKETWORKS . KEVIN MURPHY TOOK A OLDS CUTLASS WITH A 350 OLDS THAT RAN .7 UNDER IN GT/JA DRILLED HOLES IN HIS MANIFOLD FOR INJECTORS AND SWITCHED THE LETTERS ON HIS WINDOWS TO AN M AND WAS #1 QUALIFIER AT THE BOWLING GREEN OPEN . 1.18 UNDER AND 800 LBS HEAVY. HOW MANY LOW QUALIFIER SPOTS WILL THIS BOTTLE ROCKET SCIENTIST STEAL BEFORE SOMETHING IS DONE. I THINK EVERYONE SHOULD BUILD ONE OF THESE AND DEBUT THEM ALL AT THE U.S. NATIONALS AND SEE WHO CAN GO 3 SECONDS UNDER!!!!!! HEY WHAT % DO YOU GET FROM THE AHFS WHEN YOU GO 3 SECONDS UNDER? IT IS TIME TO TAKE OUT THE TRASH. DON'T LET PEOPLE LIKE KEVIN MURPHY AND DENNIS DUNLAP RUIN CLASS RACING. SOMETHING MUST BE DONE ABOUT BOGUS COMBINATIONS!!!!!
Sarg Snafo is offline   Reply With Quote
