Old 01-28-2009, 05:45 PM   #1
lorne
Default shipping weight
i have a 68 firebird and i need to know the factory shipping weight.iam running 350/305 hp gm crate what class does this fit in.thanks lorne
lorne is offline   Reply With Quote
Old 01-28-2009, 06:11 PM   #2
CrateCamaro
CrateCamaro's Avatar
Liked 19 Times in 7 Posts
Default Re: shipping weight
I run a 330hp crate at 9.5lbs and im alowed a minimum of 3400lbs w/driver. Thats in H/CM.
With a 300hp combo your probably going to be in I or J depending on how light you can get it. In I (10lbs) you will weigh 3230 and in J (10.5lbs) you will weigh 3373. If you still have all the interior, stock style multi leaf springs and stock tank or big fuel cell (12gal) like myself you will fit J no problem. I was 3375 at the national event and had to add 25 lbs to make 3400.
Tony Valerio 1968 Camaro
1700 IHRA H/CM
1701 NHRA SS/?A
Old 01-28-2009, 06:38 PM   #3
FED 387
Liked 333 Times in 180 Posts
Exclamation Re: shipping weight
68 f'bird coupe 350 v8 shipping weight is 3222-3300 pounds --Comp 387
