Old 01-24-2009, 05:19 PM   #1
hotrod
Default Baseline T-Stop set up
Need a little help here guys...Car i bought runs 5.85 very consistent all out....i wanna run S/R 6.40 with this car. I have the throtle stop rpm set @ 4100 and gonna be shifting on time...........How much amount of time do yall think it needs and where should i hit the t-stop in the run??? Thanks guys
hotrod is offline   Reply With Quote
Old 01-24-2009, 07:33 PM   #2
Lou SG2340
Default Re: Baseline T-Stop set up
Mine is stop on at .20 @ shift at .40 but I am 2200lb 565. Every car is different.
The sooner you can turn the stop on & get in high gear the less time you will be on the stop.
Lou SG2340 is offline   Reply With Quote
Old 01-24-2009, 08:07 PM   #3
Duane Dagostino
Lou...your on at .200 or .020...just asking..thanx
Duane Dagostino is offline   Reply With Quote
Old 01-24-2009, 11:30 PM   #4
63corvette
Liked 362 Times in 105 Posts
Another part of the equation is where your starting line chip is.
I run .07 stop on shift to high at 1.0 with a 565 BBC with std Brodix BBC heads.
Starting line chip of 5000 to 5600 depending on what the adjusted altitude is.
Good Luck with the setup. It takes a few passes to decide just what the car likes and they are ALL different.
My 2 Cents
63corvette is offline   Reply With Quote
Old 01-25-2009, 01:21 AM   #5
Jeff Beckman
Jeff Beckman's Avatar
Send a message via AIM to Jeff Beckman
Talking Re: Baseline T-Stop set up
With the limited amount of time you are trying to loose, dont wad the tire up and put the car flat on its nose. It will not recover the same as a car with a little more zoom. I might try leaving soft, say 5000 RPM and shift to high gear at .01, that might scrub most of your half second of stop time. Then raise your stop RPM and see what it runs. As LITTLE stop as early as possible, be gentle on the load and unload of the suspension for repeatability. That be maybe my 2 non cents worth. Or you could ask the HITTER! Sorry Dude, wherever you are, but you brought this fun on yourself.
Jeff Beckman 318J ET, SG
318T SC
Jeff Beckman is offline   Reply With Quote
Old 01-25-2009, 09:14 AM   #6
CBS
CBS's Avatar
Liked 4 Times in 2 Posts
ouch!
CBS is offline   Reply With Quote
Old 01-25-2009, 10:00 AM   #7
VanPelt
VanPelt's Avatar
Another well said statement for the day Jeff! This is more fun that a comedy club. Keep it up.
Cheers
VanPelt is offline   Reply With Quote
Old 01-25-2009, 05:56 PM   #8
Lou SG2340
Sorry I was thinking. .020 & .040
Old 01-26-2009, 06:41 AM   #9
hotrod
Alright this is what i've come up with so far.I have a gas carb set up, I leave @ 4000 chip,T-stop RPM about 4200,T-stop comes on @ .30 ,shifts @ .40,T-stop goes off @ .80 .......So do yall think that sounds about right ?? Is all that to soon in the run??
Old 01-26-2009, 11:10 AM   #10
63corvette
My opinion would be to chip it higher.
Unless you have a 1000 HP plus to launch the car I do not think 4000 chip is nearly enough to cut the light and get the momentum started.
I usually chip mine 5000 to 5600 depending on the adjusted altitude but I do bring the TS on at .07.
My car only weighs 2165 with me in it and it takes that to get it off and going.
I also am of the opinion that about 1 sec total in the TS timer is a minimum.
Most cars need that amount of time to settle down and then let it come back off the stop to full power.
Just a suggestion.
Track Time is the only way to see what the car really likes.
Good Luck
