Old 01-19-2009, 03:38 PM   #1
jltefft1
Default Boss 302 stocker
I wanted to know if there are any competitive Boss 302 mustangs running in stock eliminator? Of the Trans Am cars of 69, produced by four manufactures, the only ones I see running are the Z/28's and I think a 340/TA Challenger. I think the 340 T/A set the C/SA record last year but isn't a true T/A car. I think the cubic inch limit was 304. Thank you in advance. Jim Tefft
jltefft1 is offline   Reply With Quote
Old 01-20-2009, 01:07 AM   #2
Geerhead55
Liked 5 Times in 5 Posts
Red face Re: Boss 302 stocker
I could be wrong here, being a Chevy guy,, but weren't the 340 T/A cars all 4 speeds? I didn't think Mopar put a Torqueflite behind that engine, which would keep it out of C/SA.
Danny Durham
Old 01-20-2009, 01:20 AM   #3
David Lee
Liked 346 Times in 126 Posts
Default Re: Boss 302 stocker
Danny Durham
Both the TA and the AAR came with auto trans too. I have owned my AAR for 32 years
Old 01-20-2009, 01:54 AM   #4
bill dedman
Liked 6 Times in 4 Posts
Unless I am badly mistaken, the 340 T/A and AAR drag cars never had the right power-to-weight factor to run C/SA. They usually ran E/SA or F/SA.
The REAL TransAm E-body Mopars had a de-stroked 340 with 304 cubic inches, but the dealerships never got their hands on any of those to sell.
There was a pink 340 NHRA Stocker from Apple Valley CA, driven by a girl, who ran competitively in Division seven for several years, and I think it ran E/SA. As an aside, the guy who tuned it told me one day, that it ran marginally quicker and faster with single 750 Thermoquad carb than it did with the three twos.
What you may have seen in C/SA was a '70 Barracuda or Dodge Challenger with a 440 6-pack engine; I believe they ran C/SA, or B/SA, depending on their ballast situation.
Hope this helps...
Bill
Bill
bill dedman is offline   Reply With Quote
Old 01-20-2009, 01:58 AM   #5
Tom P
Liked 239 Times in 94 Posts
John Buczinski (sp?) runs an AAR in E/SA. I've never seen a Boss 302 Stocker but somebody runs the engine in SS... George Wright maybe?
Old 01-20-2009, 04:06 AM   #6
Jeff Lee
Jeff Lee's Avatar
One of the fastest D/SA car in the country was a T/A Challenger. Record was held and retired @ 10.56? And it's 12:55 am and I'm drawing a blank to the name of this California racer. In fact I'm embarrased...he ran D/SA while I ran D/S and we both ran almost identical times track to track. Oh crap, now I won't get any sleep...
Rod Green has a D/S T/A Challenger in the works. The T/A can run C/S-A, D/S-A or E/S-A as the car falls at 9.59 (at) or 9.83 (stick).
The AAR 'Cuda falls at 10.09 / 10.34 making it a D/E/F car.
Back to the original question, nobody has raced a '69 or '70 Boss 302 in a long time. None that I'm aware of at least. But I've always thought "if I had money to burn", I would build a '70 Boss 302. With the camshaft and valvetrain technology available today, along with the clutches & transmissions we have (don't forget aftermarket rods too), I believe you could launch the car at 8K whereas once before that may not have been possible on a 9" slick. The '70 would still be the way to go due to the smaller ports.
Dynacor just released their aftermarket '69-'70 Mustang FB so now you could build the car the right way without dealing with a 39-40 year old body.
And if it just doesn't work at all, just pull out the 302 and drop in a 428.
But I really think the 302 will work. If nothing it would be a lot of fun!
The '69-'70 Boss 302 are NHRA rated @ 305HP and both years fall into F/S so you can run E/F/G (stick only). Figure 3220#'s in E/S.
Cam lift (.502" I/E) and compression look the same both years. I'm not sure if the head specs are the same with superseded parts.
Jeff Lee 7494 D/S '70 AMX
Old 01-20-2009, 04:13 AM   #7
Jeff Lee
Jeff Lee's Avatar
Danny Durham
1970 Challenger T/A: 1410 built with 727 TF, 989 with manual trans.
1970 'Cuda AAR: 1604 built w/ 727 TF, 1120 built with manual trans.
Old 01-20-2009, 08:36 AM   #8
BlueOval Ralph
Banned
The 69 & 70 Boss 302 head are same ports only difference is 69 had 2.24 intake valve and 70 had 2.19 intake. Also stay away from the Doze-A block as it was not a square bore casting and will not stand +.060 over bore.
Ralph
BlueOval Ralph is offline   Reply With Quote
Old 01-20-2009, 09:07 AM   #9
bsa633
Banned
Gene Buell!
bsa633 is offline   Reply With Quote
Old 01-20-2009, 12:41 PM   #10
Myron Piatek
Liked 138 Times in 51 Posts
Exclamation Re: Boss 302 stocker
Hope this helps...
Bill
You are mistaken. As named in the last post, it was Gene Buell who set the C/SA record with a 1970 Challenger T/A with a 340-6. The original factors had them in slower classes because they were difficult to make run competitively. But he apparently got it figured out and got factored several times unil the car could actually make C/SA.
Check out a National Dragster from last Summer or so. I believe it was a factored 10.33, but apparently retired/reset last year.
But you are correct about the owners of the pink Challenger running faster with a TQ as a '71 than it did with a 6 pack as a '70.
As for the Boss 302 in Stock, my ex-boss had one in the day and always complained that the Z-28's would always get out quicker and a 1/4 mile just wasn't quite enough to reel them in. (Paul Duzs - York or US 30, or something like that.
LOCOMOTION Racing
