Old 01-12-2009, 07:08 PM   #1
Thurston
Thurston's Avatar
Default Changing Combo Sale
1. MW Aluminum drive shaft: 35.5 center to center 4inch dia. $400.00
2. Ron's Flying Toilet: 5inch throttle blade, dominator flange, comes with barrel valve, nozzle lines, port body's and nozzles and idle pass pass if needed. $900.00
3. BG Fuel Pump: Model 280 $175.00
4. Impact Seat Belts:Wrap around 5 point, Cam Loc, needs re-cert: $75.00
5. Trans Yoke-New: fits 904/Torqueflite, quick change style $150.00
6. Trans Yoke Used: 16 Spline G Force $100.00
7. Gebbler Stainless Tri-Y Stepped Headers: for W-8 Mopar Drag race heads. 1.750 Primaries, Stepped to 1.876, Stepped to 2.00 with 3.5inch cone shaped collectors. $850.00
These will not fit nascar heads the bolt pattern for the flange is different.
I will be at the Drag Expo in Schamburg, IL on the 24th of this month if anyone is interested in seeing any of these parts, I can bring them with me.
Thanks, Class Racer for the space.
Jim Thurston
r-thurston@sbcglobal.net
H:616-738-7140
C:616-836-5104
Thurston is offline   Reply With Quote
