Old 01-11-2009, 03:26 PM   #1
SS/J
Default 68 340 HP / Factor / Class ?
what is the IHRA factored horse power for a 68 340?
what are the options for the class J or K ?
what are the minimum weights for these classes?
SS/J is offline   Reply With Quote
Old 01-11-2009, 09:58 PM   #2
RJ
Default Re: 68 340 HP / Factor / Class ?
IHRA uses the NHRA factors and specs for the most part, in some cases there may be a hp difference, and IHRA usually publishes it on their website. The 68 Dart or 68 Barracuda fastback can run I, J, or K.
Minimum weights with driver -
SS/I = 2980 lbs.
SS/J = 3261 lbs.
SS/K = 3542 lbs.
NHRA has all the 68-71 340 combos' cylinder head intake port volume info wrong at this point, they seem to think that the 68-71 heads with 2.020" intake valves should hold the same port volume as the 73 340 and the 74-up 360 heads with 1.880" valves?
RJ is offline   Reply With Quote
