Old 01-08-2009, 09:15 PM   #1
RuggedRacing
RuggedRacing's Avatar
Default For Sale--Innovative Motorsports A/F Ratio Meter & J & J Performance Engine Diaper
Innovative Motorsports LM-1 Air/Fuel Ratio Meter (Kit): With the LM-1, precise AFR measurement allows the user to correctly adjust many variables- including carburetor jetting, fuel injection, turbo fuel curves, etc.- without long and expensive dyno sessions. Includes: LM1, RPM Converter (Aux Input #2), Bosch 5-wire Wideband 02 Sensor, Analog Output Cable, 10ft. Sensor Cable, 10ft. Power Cable (Cig), 6ft. Serial Cable for PC Connection, Bung/Plug Kit, Software CD, and Quick Start Guide.
This is a used item and was in a dragster for only one year. There is nothing wrong with it. Asking $300
J & J Performance Engine Diaper: For 6 to 13 quart pans with an external oil pump, these diapers include mounting hardware, oil-absorbent pad & front/rear straps to keep diaper from balancer & flywheel. SFI 7.2 approved. This is a used item and was in a dragster for only one year. There is nothing wrong with it. Asking $200
E-Mail-RuggedRacing1900@aol.com or call 516-621-8897
RuggedRacing is offline   Reply With Quote
