Old 01-06-2009, 06:31 PM   #1
brutuswedge
Default Removing rear window crank regulator
Want to remove the rear window crank regulator mechanisms from a '67 Camaro. Need advise as to how I can pin or keep the rear window up & in place tight. Am going to keep the glass, just loose the regulators.
brutuswedge is offline   Reply With Quote
Old 01-09-2009, 12:12 AM   #2
FED 387
Liked 333 Times in 180 Posts
Default Re: Removing rear window crank regulator
take a small piece of aluminum and pop rivet it to the bracing and position it to hold the bottom of the window /glass framing it in position---Comp 387
