Old 01-04-2009, 05:23 PM   #1
jmahar
Default 65 Plymouth Vailiant Race Car
1965 Plymouth Valiant -
360 by Precision Cylinder Heads
Ported "J" Heads - Flat Tappet Cam - 12.1 Compression - H-beam Rods -
Victor 340 - 825 CFM Demon - MSD 7AL ignition
Pro Trans lite weight - rollerized 904 with 8" Munsinger Converter
PMR full chromoly cage round tube back 1/2 - 9" Ford rear end aluminum center section with back cut 5.14 Richmond Pro Gear - Moser gun drilled and lightened 35 spline axles - 14X32 Hoosiers -
Alter-K-Tion front suspension - Wilwood disk brakes all around
Car is all steel with a fiberglass hood and lexan windows. Car without driver or ballast weighs 2480 lbs
This car was completed in May 2008 and this season has had 1 win 1 runner up, and finished 3rd in Southern California Electronics Drag Racing Association (SCEDA) Electronics category in the first year out - a proven winner - very consistent and fun to drive.
Car has run 10.20 at 130mph in less than ideal conditions at 2820 lbs.
Have throttle stop and electronics to run S/ST -
$18,500
Call Jim
(714) 604-5938
jmahar is offline   Reply With Quote
