Old 01-04-2009, 11:07 AM   #1
jimblair
Default bbc &sbc parts
bbc parts
1 set shubek lifters(solid) $400.00
1 set Manley sportman rods, balanced big end & small end within
4/10 0f a gram,calico coated,new 8740 bolts,within 5/10 of a thousand in length from center of small end to center of big end & resized big end close to maximun crush. $1000.00
1 set GM 7/16 bolt dimple rod,new in the box. GM#8045PB $500.00
1 GM steel crank #6223 stoked to 3.779, .020 rods, .020 mains
balanced to 1575.8 grams piston and rod assembly. $500.00
1 set of long slot rockers, 3/8 push rods, guide plates (crane), & 7/16 studs & lock nuts. $225.00
1 set intake & exhaust valves new 2.19 manley #11832 & 1.84 ferrea #f2107p for aluminum heads. $120.00
2 sbc cranks small journal 327-#3782680 283-#3876768 std. $300.00
each
2 sbc blocks, 327 #3782870 std.date A-7-63
283 #3896944 std. date K-22-66 $300.00
each
Contact Jim Blair 605-224-4648 or sandiblair@msn.com
jimblair is offline   Reply With Quote
