Old 12-30-2008, 06:44 AM   #1
Bud Lefevre
Bud Lefevre's Avatar
Default Older diesel ?
Looking at a possable tow vehicle, 1991 Suburban 2500 with a 6.2 diesel , 150,000 miles. Any pro's or con's on this for towing ?
Thanks
Bud Lefevre 3075 STK
IHRA World Record Holder
Bud Lefevre is offline   Reply With Quote
Old 12-30-2008, 08:14 AM   #2
bobby
bobby's Avatar
Default Re: Older diesel ?
Lotsa torque, no H.P. will get you going, but won't keep you there.
Next time wave all of your fingers at me.
bobby is offline   Reply With Quote
Old 12-30-2008, 09:18 AM   #3
Bruce Schoenbaechler
Also good for breaking cranks and harmonic balancers
SCHOENY
Bruce Schoenbaechler is offline   Reply With Quote
Old 12-30-2008, 09:32 AM   #4
Lou SG2340
We use to have 4 trucks with these motors at work.Not reliable past 100,000 miles.Had block & head warpage problems.
Lou SG2340 is offline   Reply With Quote
Old 12-30-2008, 09:34 AM   #5
Mike Pearson
Mike Pearson's Avatar
Liked 1,943 Times in 584 Posts
Bud,
If you are looking to tow with an older diesel pick up truck I would recommend a ford F350 with a 7.3 liter diesel. They were available from 1997 to 2002. They are real reliable and have lots of power. If you can find one with reasonable miles on it you will have a great truck. I had a 99 and loved it. I now have a 2005 chevy with a duramax diesel. It tows well also.
Mike Pearson 2485 SS
Old 12-30-2008, 10:01 AM   #6
Liked 1,851 Times in 418 Posts
I've got a couple of friends who have or had those. They are not the best diesel out there, but good service can be had with proper care. The later 6.5 is better. A close friend had a 97 with a 5 speed for 9 years, and about 450K miles. The 5 speed gave some trouble, but the engine was fine. It had 4.10 gears, we put a Flowmaster on it, took the converter off, and put a K&N filter in it, and it ran strong. We pulled a 32' enclosed goose neck with a Pro Street car in it for about 1/2 those miles, and rarely got under 70MPH, it got about 15 MPG. Far as I know, the truck is still running.
Old 12-30-2008, 11:01 AM   #7
Mark Ruset
Mark Ruset's Avatar
Liked 43 Times in 29 Posts
Bud,
If memory serves me correctly those engines had injection pump problems.You would be better off with something newer. If you can step up to a new Duramax I know the dealers are selling them at a loss.
Mark Ruset 2048 STK
Mark Ruset is offline   Reply With Quote
Old 12-30-2008, 02:15 PM   #8
Harry 6674
Alot of people have swapped the 5.9 cummins in the chevy trucks and burbs.
Harry 6674 is offline   Reply With Quote
Old 12-30-2008, 06:48 PM   #9
buzzinhalfdozen
Liked 11 Times in 8 Posts
6.2 was a fairly reliable piece for most of the farmers around here, however they never hooked to a trailer and tried to travel any distance either. They suffer some common ailments , Inj. pumps glow plugs damper breakage Ect. not in my opinion worth the risk if you're looking to do some traveling with it. These were in my opinion about the worst attempt at a diesel engine by the big 3. Save yourself alot of trouble and get a 7.3 powered ford or a mid 2000 G.M. duramut. Can't say anything good about the Dodge except Cummins does make a very good diesel engine. Joe
Joe Buchanan SS/BX 3117
Old 12-30-2008, 07:20 PM   #10
sst3447
I have had both 6.2 and 6.5 in my tow vehicals put injector pumps on both cylinder heads on the 6.5 , they both are underpowered and if you tow a large trailer you will have overheating problems my 6.5 would run about 240 degrees towing my gooseneck i would stay away . my duramax will pull with no problems
sst3447 is offline   Reply With Quote
