Old 12-27-2008, 09:15 PM   #1
Jamie Greening
Default 2 Dedenbear Case Glides
Glide 1 is a Dedenbear case & tailhousing, glide input, Aluminum Drum & hub, 1.98 gear, Hughes pro tree brake, deep cast pan, 40 runs from new, fresh $2200 Glide 2 is a Dedenbear case & tailhousing, glide input, Steel drum & hub, 1.96 gear, full tree brake, Dedenbear pan, 32 runs from fresh, $2000 Call Jamie at 573-449-8003 leave message if no answer will return calls Thanks
Jamie Greening is offline   Reply With Quote
