Old 12-27-2008, 03:55 PM   #1
Mark Faul
Liked 43 Times in 9 Posts
Default Garage Sale
New "401" aluminum BBC GM Performance Parts heads, bare. $749 at Scoggin Dickey, $773.99 at Jegs each. $1300 for the pair.
Used MSD 8680 Adjustable Timing Control, 0-15 degrees. $157.99 new at Jegs. $75
Used MSD 8673 RPM Module Selector 7600-9800 $63.99 new at Jegs. $30
Used Comp springs 948-16, all are 275-300lbs @ 2.000 installed height. $75
All of the following cam lift specs are in lobe lift.
Used Bullet 50mm cam, SBC, #S399. CHS 307-318-7R .428 273* int, .440 285* ex on 107 LS. $100
Used CamMotion standard core SBC #I7020 328-5 340-3 R8 .441 268* int, .423 272* ex on 107 LS. $75
Used Erson standard core SBC #4257 .450 278 both int and ex on 102 LS. $75
Heads are sold!
Any questions please PM, call or email. Thank you!
mark@markfaulracing.com
253-906-9643
Mark Faul is offline   Reply With Quote
