Old 12-26-2008, 11:36 PM   #1
astikhossw
astikhossw's Avatar
Liked 20 Times in 9 Posts
Thumbs up cam spec results
can anyone tell me if they have raced or dynoed a cam with these spec.s' and if so can you tell what kind of hp and torque did you get out of the engine and at what rpm,spec's or :@.050 intake 278 duration .465 lobe lift and exhaust @.050 292 duration .440 exhaust lift using a 1.7 intake rocker intake 1.65 exhaust, lobe separation 108
astikhossw is offline   Reply With Quote
Old 01-19-2009, 01:56 PM   #2
big blue galaxie
Default Re: cam spec results
Unfortunately for that type of question, you have to say what kind of engine you have. Further still, why don't you give Jones Cam Designs a call since he has one of the most accurate modelling programs around. Their number is 704-489-2449
big blue galaxie is offline   Reply With Quote
Old 01-19-2009, 03:57 PM   #3
trmnatr
I have used this grind
307/317 @.020"
278/264 @.050"
201/197 @.200"
.684"/.660"
106 degree lobe seperation @ 106icl
HXL / RZ lobes
7800rpm shifts
8200rpm past the lights
317/330 @.020"
283/291 @.050"
201/? @.200"
.680"/.632"
Lunati
7800rpm shifts
8400rpm past lights
327 small block with 3.25" stroke so in a large engine im not sure what they would turn
How about some more info about your combo? Heads? Bore? Stroke?
trmnatr is offline   Reply With Quote
Old 01-20-2009, 09:32 AM   #4
Mike Pearson
Mike Pearson's Avatar
Liked 1,943 Times in 584 Posts
Are trying to use this cam in a small block chevy? It looks like its a stick shift cam.
Mike Pearson 2485 SS
