Old 12-24-2008, 02:47 PM   #1
11s42k
Default Pistons - 327 Stocker, SBC, SBF - make offer!
Open to offers on any of these. Pictures at:
http://s307.photobucket.com/albums/n...awsoe/pistons/
SMALL BLOCK CHEVY:
(8)New Venolia Chevy 327 275/325 Stocker Pistons
4.035 piston diameter, Includes rings, but no pins. $450
(8)New BME SBC Pistons
Bore: 4.155, 1.270 Compression Height, 453 grams (on box).
Big domes. Never run. Were intended to be run with a Brodix Pontiac head. $500
(8)New Keith Black p/n 231 Pistons
Chevy 350 flat top piston. 4.040" Bore. 6cc valve reliefs. Compression ratio with a 58cc head will be 11.1 to 1 and with a 64cc it will be 10.3 to 1. They use 1/64; 1/64; 3/16" rings. $250
(8)Almost New JE Custom Pistons P/N 227596
Bore: 4.000”, 0.927” pin, 0.250” dome, 1.100” Compression height.
Built for N351 head. We assembled the whole engine in a hurry and fired it up. It made bad noises. We didn't have N351 heads. The valves all tagged the reliefs. We pulled it back out and had to get the correct pistons. These have only seconds of run time on them and never left the garage. Includes pins and rings if you want them (the were already filed for a 4.000 bore with large gaps for nitrous). Asking $400.
Email me at lawsoe@q.com, or call 507-457-3126 evenings before 10 Central time. Add $20 for shipping if necessary.
11s42k is offline   Reply With Quote
Old 12-31-2008, 09:49 PM   #2
Greg Reimer 7376
Liked 719 Times in 220 Posts
Default Re: Pistons - 327 Stocker, SBC, SBF - make offer!
Hi.I'm interested in the 327 stocker pistons and rings.Still got them? Email at chevellegreg7376@hotmail.com if you do, maybe we'll put some deal together. Thanks!! Greg
Old 11-17-2010, 10:02 AM   #3
actionange
Default intake manifold wanted
Edelbrock LD4B intake for small block Mopar
Any out there?
Email at: actionange@yahoo.com
actionange is offline   Reply With Quote
Old 11-18-2010, 12:03 PM   #4
Larry Fulton
Larry Fulton's Avatar
PM & E-MAIL SENT
Thank You
Larry Fulton
Larry Fulton is offline   Reply With Quote
