Old 12-07-2008, 04:51 PM   #1
Clayton Wright
Liked 13 Times in 4 Posts
Default MoPar 426 Max Wedge parts
1- Standard bore 1963 Max Wedge block dated 2/12/63
1- Max Wedge crankshaft standard
2- Stage 1 Max Wedge heads, stock
2- Sets stage 1 rocker arm assemblies
1- Stage 1 cross ram manifold
2- 3447 carter carbs
1- Set Max Wedge rods
2- Sets Max Wedge valves. 1 used & 1 new with chrome valve stems
2- Sets timing chain & gears. 1 set used very little & 1 set new
1- Set stock valve springs
1- Racer Brown STX23 cam, lifters, retainers & springs
Just what you need to complete your restoration. $10,000.00 Takes it all.
If any questions please call 215-788-1107.
Clayton Wright 1980 STK
Clayton Wright is offline   Reply With Quote
