How many racers do this?
How many racers with a TH400 Transbrake car push it into Nuetral
I have talked to the guys with that make the Clean Nuetral valve bodies and it seems as if the only difference is Nuetral is behind high gear
Do you push your TH400 in Nuetral by passing over 3-2-1 into Nuetral ? I dont see any issue with it because your passing over the gears,, your not making enough fluid pressure to engage clutches etc when passing over them (kind of like passing over reverse when going from park to low gear)
I know this is an opinion subjest so let hear them,,,
Opinions?
