Old 12-02-2008, 10:55 PM   #1
Lynnmsp
Default sbc connecting rods
Looking for new rods for my project.What are your likes or dislikes of eagles,oliver,comstar,lunati pro mods I beam or H beam.I had a set of I beams (lunati pro mods) which broke after 91 runs.They were I Beam and broke in 4 pieces and never hurt the crank.Motor never see's over 7200.
Lynnmsp is offline   Reply With Quote
Old 12-03-2008, 12:15 AM   #2
Darrin Christen
Darrin Christen's Avatar
Thumbs up Re: sbc connecting rods
I've been running Lunati Pro Mod rods 5.7" in my 355" sbc for years. I put hundreds of runs on them, crosses at 8000-8200 rpm. After several years of running them I replaced them with another new set of the same rods just because I didn't know how long they would last. I guess it just depends on the application.
4878 SS/GA 66CHEVY II
Darrin Christen is offline   Reply With Quote
Old 12-03-2008, 01:13 AM   #3
curtis hieb
curtis hieb's Avatar
Liked 9 Times in 8 Posts
Default Re: sbc connecting rods
I use howards rods in my 427 small block over 350 passes they are billet if I remember good for 800 hp I dont work the engine to hard 7100 through the lites. They are 6 inch rods. Runs 10.90 at 134
curtis hieb is offline   Reply With Quote
Old 12-03-2008, 08:13 AM   #4
rod butcher
Liked 132 Times in 27 Posts
I use Oliver billet 6" rods in my 434. I have 200 runs on them running @ 7800. I mag them every 100 runs or so. I think these are the best rods for high hp bracket small blocks. My motor makes 830 on the pump and runs 10.90@ 151.00 at 2830 lbs. If you need help or info send me a pm.
rod
rod butcher is offline   Reply With Quote
Old 12-03-2008, 12:57 PM   #5
trmnatr
rod
What the heck, Who do you run an ET with a MPH 1.0 seconds faster?
Is it like a throttle stop car or something? Im a little confused at your ET VS MPH
trmnatr is offline   Reply With Quote
Old 12-03-2008, 12:58 PM   #6
trmnatr
rod
Just asking because my Camaro @ 2800 runs 10.41-10.50 @ 127-128.42mph
Do you hook good?
Old 12-03-2008, 01:09 PM   #7
Darrin Christen
Smile Re: sbc connecting rods
Yes, that would be a throttle stop car. Super Sreet(NHRA) or Hot Rod(IHRA). And a very fast small block 10.90 class car for sure.
Old 12-03-2008, 03:31 PM   #8
Eddie Arnold Jr.
Prior to last year
I ran a 421 SBC with dart 23 degree heads in S/G , 9.90 @ 148/150 MPH ,,, Motor in my Cutlass would run 8.70's @ 154 all out -----I put about 400 runs on a set of LA Enterprise / kryptonite 6" steel rods ,,, I would leave on the converter every pass ( 5800/5900 RPM ) and go through @ 7700/7800 ,,,, Never broke a rod !!!--- 3years ago I spun a bearing and switch to Comp Star steel rods and never had a problem ,,
sold motor last year and new owner hasn't had any problems ,,,,, I've ran just about all the rods over the years and the one caution is watch the weight specificly if you will be twisting this thing above 7500 ,,,
the Olivers , Carrilo's , Crowers , Lunati etc are all good but some are very Heavy !
Colorful Racer
Eddie Arnold Jr. 3934 SC, SG
Eddie Arnold Jr. is offline   Reply With Quote
Old 12-04-2008, 05:17 PM   #9
rod butcher
trmnarr
I have run my car in S/St and H/R the last couple of years. My driver (son) likes to chase. Flat out the car has gone 8.52 @ 157.00 with a 1.21 60' time. On the throttle stop 10.90@ 151 with a 2.10 60' time. If I were still in the seat I would be running s/g
rod
