Old 11-27-2008, 06:14 PM   #1
skauto
Default 252" Chassis Craft
Comp eliminator car built for A/ED and never finished for that class, i have run this as a bracket car with a mild 406 which is loaded with good parts,motor is a gm performance splayed cap block with steel phase 2 bowtie heads gm intake, steel crank h beam rods and je flat tops, solid lifter cam(have a roller and lifters ) to go with it.stephs wet sump pan sigle stage oil pump with system one filter jessel belt drive front mount dist with crank trigger, a1 power glide 5500 convertor,coupled to a 35 spline strange aluminium center. car runs 8.50 at 150 all day long. asking 22,000 cad obo. also have all the parts to make a 377 comp motor if interested for additional cost
skauto is offline   Reply With Quote
