Old 10-22-2008, 10:36 PM   #1
THE LEGEND
Default 468 Chevy
468-
Callies Cank
Carrillo Rods
JE pistons
Brodix heads
Brodix intake for 4150 and extra brodix intake for dominator
Jesel beltdrive
Crane Rockers
MSD crank trigger
MSD distributor
Roller cam
Mezeire water pump
Milodon Pan
AED 1000 series carb
Custom set of Jet hot coated headers with Lemmons collector mufflers for tube chassis door car
Motor will run 5.80's/90's in 2800 lb door car
Has around 100 passes most on T-stop
Will take to track so you can see it run then pull it out.
$8,500 with carb $7,500 w/o
Chip Johnson
910-309-1760
THE LEGEND is offline   Reply With Quote
