Old 10-17-2008, 10:19 PM   #1
Chad E532
Chad E532's Avatar
Liked 54 Times in 7 Posts
Default Safety Harness Seat Feed Thru
Has anyone ever seen a plastic bushing that you can use when you take your stock seats and cut slots for the shoulder straps to feed thru?
I am envisioning a plastic oval tube 1/2" tall x 3" wide with a flare on the end to insert into the seat to keep the harness straps from rubbing on any inside the seat.
I have high backed buckets (77 Camaro) and the tech guy at my local track recommended that I feed the belts thru the seat because the seats are pretty wide at my shoulders and the belts would not keep me restrained very well.
I looked online at various belt suppliers and none of them make this sort of product.
Let me know if you have any suggestions on what to use.
Thanks,
Chad
Chad E532 is offline   Reply With Quote
Old 10-18-2008, 12:37 AM   #2
Philip Saran
Liked 14 Times in 11 Posts
Default Re: Safety Harness Seat Feed Thru
Chad,
I know what your looking for, but all the one's I've seen done have
have been done by a upholstery shop.
But that plastic part might also be something from a seatbelt harness
off of a chevy.
Phil Saran
Parker, Colorado
Philip Saran is offline   Reply With Quote
Old 10-18-2008, 08:09 AM   #3
Bob Verwold
Bob Verwold's Avatar
I think some of your older Chev pickup tk's have what your looking for (74--about 89).............
Bob Verwold is offline   Reply With Quote
Old 10-18-2008, 10:19 AM   #4
Terry Cain
Terry Cain's Avatar
Liked 231 Times in 107 Posts
Take a piece of PVC pipe, heat it with a heat gun and then form it to the shape you'd like.
Terry Cain ???? STK
tcain19689585@gmail.com
Terry Cain is offline   Reply With Quote
Old 10-18-2008, 09:20 PM   #5
Jim Carter
Liked 19 Times in 3 Posts
Thumbs up Re: Safety Harness Seat Feed Thru
Check with your local Chevy parts guy. My 1994 Suburban has a seat belt grommet similar to what I think you are looking for Other years must have had them as well. It is a pass through for the front seat, its hard plastic and it has a lip on it. I think it'll do the job
JimmieC
Jim Carter is offline   Reply With Quote
Old 10-19-2008, 02:29 PM   #6
Chad E532
Chad E532's Avatar
Thanks for all the various ideas. I am planning a trip out to the junkyard to look at the various vehicles that you mentioned.
Chad
