Old 10-04-2008, 11:15 AM   #1
Comp 798
Comp 798's Avatar
Default Super Stock Camaro "REDUCED PRICE"
The car was completed in 2000 by MPR (Mike Pustelny) from a new 97 Camaro. There were three owners. Dave Billingsley, Tommy Phillips and Bret Voges. I bought it as a turn key SS/GT car from Bret Voges in 2005. It was updated and set up for Comp and SS/Mod by Phil Mandella 1/07.
Can run Comp, SS/Mod or Mod Stock, GT and SS. Currently SS/BS. Went 1.341 under first time out during slowest session of the event @ Boise. New Mike Blackstone/Watson Racing 10 degree motor with the absolute best parts. "4 passes on motor"! Less than 20 passes on the car since 1/07! This car is clean with many new parts. Have both hoods, 2 sets of headers and all pieces to run SS or GT.
Motor:
331cu. In. 4.125X3.100
New Bob Book (BRE) 750 Carb
HRE Manifold and Spacer
HRD 10 degree heads/CV Titanium valves and 8-degree retainers (7mm and 5/16)
CV radius groove locks, lash caps. All bearings coated.
Diamond pistons, molds by Rebco (lightened, gas ports and coated)
MGP rods
Cam Motion 55mm roller (custom grind), Manley 221450-16 springs.
Jessel: lifters, rockers, belt drive and front drive distributor.
Crower ultra-lite crank, 1.88 & 2.297 (custom grind, nitride, polish and balance)
Peterson Wet Vac/external oil pump, CV remote filter, Jones mandrel (gilmer)
Trend 9.27/7/16 and 9.27/7/16-3/8 pushrods
Bowtie block, fresh bore, decked, squared, line bored, honed, front oil feed, lifter valley vents, bronze lifter guides, ARP head studs
Steffs oil pan for external pump w/new style baffle
Felpro: 1143 head gasket, 1886 oil pan, 1628 valve cover, 1283 intake
ARP valve cover studs, carb studs and all bolts
Watson Racing custom polished fab/aluminum valve covers
Mark Williams:
Brakes, Axles, Drive Shaft and Third member in a Fab 9 Housing. New rear rotors, all 4 calipers rebuilt by Mark Williams and new Ferodo pads at Phoenix 07. Richmond lightened and coated ring and pinion from Mark Williams new in 07, less than 20 passes.
Grant steering wheel on a Mark Williams quick release hub.
Afco double adjustable coil overs (4) rebuilt by Afco for 07 season.
Weld Aluma-Star 2.0 (4), Hoosier front and New M/T 3074R (4-runs) on rear.
Autometer Ultra Lite: Tach, Water Temp, Oil Pressure, Data Logger w/G-Meter, 8 egt’s, Engine rpm, Drive rpm, Fuel pressure, Engine/Drive ratio and aux channels with software and manual.
ADP air shift control module, Precision Performance Shifter (new 07). Shifter mount is adjustable for height, angle and rotation. New Biondo Terminator transbrake switch.
Two-piece removable trans tunnel w/Dzus fasteners, bonded carpet and Velcro attached. (All new 07).
Kirkey aluminum seats and Kirkey covers. Gforce belts good through 3/09. Stroud window net. Chassis certified to 8.50 good through 3/10.
Fiberglass/Carbon composite hood and scoop by Joe Vanoverbeek (new 07).
TurboStart 16v AGM batteries (2).
Magna Fuel Pro Star fuel pump, filter, regulator and liquid filled pressure gauge.
MSD 7AL2, Three Step and Module Selector, 3000-5200.
Deist Parachute, removable mount and cable (new 07).
Rack and pinion front mounted on a fabricated round tube cross member. No cross member under oil pan.
All chrome-moly cage.
ARC overhead fused control panel.
May separate! Would trade for the right S/C - T/D Dragster, T/S, or an excellent S/G car.
email for photos and info:
sam_tufano@hotmail.com
see racingjunk.com ad #1330442
Comp 798 is offline   Reply With Quote
Old 10-10-2008, 12:17 AM   #2
Adger Smith
Liked 880 Times in 311 Posts
Default Re: Super Stock Camaro "REDUCED PRICE"
Try a search with: Super Stock Camaro "REDUCED PRICE"
I couldn't get the ad # to work either.
Adger Smith (Former SS)
Old 10-10-2008, 10:35 AM   #3
Comp 798
Comp 798's Avatar
Ad #1330442 is correct and I tried searching by the # and the ad does come up. Any questions please email me @ sam_tufano@hotmail.com
Thanks
