Old 10-03-2008, 01:17 PM   #1
Smitty
Smitty's Avatar
Default Trans Brake Issue
Ok guys here's my problem; I have a C-4 Trans with a Dynamic Trans Brake. The trans brake uses a Ledex Solenoid to change fluid flow in the valve body. I recently changed engines and installed a new Harrington Switch from Biondo, replacing the B&M green button. My problem is that when I activate the Harrington switch for some reason when the car shifts to 2nd gear it locks the rear wheels. I can disengage the Harrigton switch and cycle the transmission a few times it works correctly via foot braking.
What do you guys think the problem is, I think I am try a B&M Mushroom switch to see if it's the switch.
Smitty is offline   Reply With Quote
Old 10-03-2008, 02:20 PM   #2
SSDiv6
Liked 1,604 Times in 583 Posts
Default Re: Trans Brake Issue
Smitty, it appears that the switch is staying energized. Do you have an arming switch too? Are you running an MSD box and two-step or line lock that is wired to the transbrake too? If you are, you may need a relay. Need more info on the circuitry.
Old 10-03-2008, 04:12 PM   #3
Smitty
Smitty's Avatar
Joe,
I am running an MSD 7AL2, MSD Two step, and MSD Shift box. Line lock is wired seperatelty from the rest of the system and there is not an arming switch or relay in this system either.
Smitty
Old 10-03-2008, 04:58 PM   #4
SSDiv6
Joe,
Smitty
Smitty,
Could you let me know the part number of the MSD box and two-step you are using? There is a particular part number of MSD box and two-step that requires a relay in the system. I need to look and my notes at home to see if you have the particular part numbers.
Old 10-03-2008, 08:56 PM   #5
Mike Graham
Liked 341 Times in 67 Posts
That transbrake valve body sometimes has a problem like you described. Try cleaning the valve body
Mike Graham is offline   Reply With Quote
Old 10-06-2008, 11:39 AM   #6
Smitty
Smitty's Avatar
Smitty,
You need the actual serial number Joe? Here are the model numbers for my other MSD Ignition parts:
MSD 2 Step Model number 8739 and MSD RPM switch Model number 8950. I will check for the other numbers on the 7AL2 later.
Old 10-06-2008, 11:39 AM   #7
Smitty
Smitty's Avatar
Thanks for the tip Mike I will look into that.
Old 10-06-2008, 11:51 AM   #8
SSDiv6
Smitty, all I needed was the part numbers. I will do some research tonight and let you know.
