Old 09-30-2008, 05:53 PM   #1
et7333
et7333's Avatar
Default Trans brake switch
Which trans brake switch do you use and why?who do you feel makes the most consistent switch on the market?
et7333 is offline   Reply With Quote
Old 09-30-2008, 07:18 PM   #2
Dave Goob Cook
Dave Goob Cook's Avatar
Default Re: Trans brake switch
Biondo "small mushroom".
It is not sensitive to finger or thumb placement, positive, repeat action.
It tests to a .007 or better range for me. Nothing else comes close.
I feel that range is the human factor, not the button.
Requires cleaning and lube (or replacement) once every 3-4 years.
Dave Goob Cook is offline   Reply With Quote
Old 09-30-2008, 07:42 PM   #3
et7333
et7333's Avatar
Dave are referring to this switch?
Old 10-01-2008, 01:41 PM   #4
mannymen
Liked 13 Times in 7 Posts
DRR has a whole write up discussing button BOUNCE comparisons and the Trans Triggers.
I have tested many of the common buttons as have others and I have found that the B&M large RED Mushroom button is the most consistent, but not the fastest in my case
N/A
mannymen is offline   Reply With Quote
Old 10-02-2008, 12:03 PM   #5
Dave Goob Cook
That is the one!
