Old 09-14-2008, 10:21 AM   #1
Jeff Teuton
Liked 325 Times in 50 Posts
Default Houston-Galveston Racers
I should have some generators coming off line this week if you are in need. I have a 30kw 1 ph, 40 kw 1 ph, and 100 kw 3 ph that should be available. They are all trailer mounted and all diesel powered and have the proper wiring coming out of the gen set. As soon as we survey the local situation on power they will be available, I will know probably Monday or Tuesday. You will need an electrician (except Charlie Ford) to wire them into you home, business whatever. Call me. 985-804-6161 We are 290 miles from the Baytown track.
Jeff Teuton 4022 STK
