Old 09-01-2008, 02:25 AM   #1
Jeff Lee
Jeff Lee's Avatar
Default Valvetrain parts - SBC - AMC - Mopar
Time to buy more parts; these I don't need laying around anymore! Some of these items are cheap enough they should be bought and thrown in the shoe box as spares.
Isky chilled iron lifters MOPAR / AMC - solid lifters converted to NHRA legal hydraulic. The lifters are impossible to locate as the EPA shut down the chilled iron process years and years ago. These are narrow in the middle. I have 27 of these and will not split. $405.00.
Sherman hydraulic lifters MOPAR / AMC - New in box. Meet NHRA specs. These sell new for around $300.00 for a set of 16. I'll sell these for $200.00.
Isky hydraulic lifters for MOPAR / AMC - New in box. These are labeled "High Quality Silent Running Hydraulic Lifters" p/n 3052-HY - AMC. 16 for $150.00.
MOPAR RB NASCAR rods - New in box. I have (4) of these relics. This is an extreme duty 426W-440 rod. dated D.C p/n: P3690649. No rust, brand new, all for $100
Comp Pushrods SBC / AMC - (16) used p/n 5003 7.900" 5/16" .080" wall 4130 chromeoly. Perfect used - $50.00
Comp Pushrods SBC / AMC - (16) used p/n 7972 7.800" 5/16" .080" wall 4130 chromeoly. Perfect used - $50.00
Manley Pushrods SBC / AMC - (16) used 4130 chromemoly 8.000" 5/16" .080" wall. Perfect used - $50.00
Manley Pushrods SBC / AMC - (15) used 4130 chromemoly 9.200" 5/16" .080" wall. Perfect used - $50.00
ARP screw-in rocker arm studs w/ ARP locks - SBC / AMC 3/8" used. I have
(14) screw in studs and (16) locks. All ARP. $25.00 for all.
Nology - Pro-Fire coil - used, perfect for $50.00.
AMC Rebel Machine intake manifold - $450.00.
Valves - AMC (8) 2.025" intake, 3/8" stem, 2-groove & (8) 1.685" exhaust 3-groove, all are stainless and perfect used - $100.00.
Rockers - AMC 1.6 new and used as described below:
(15) NOS in factory packaging
(16) perfect used valve tip have been faced
(13) perfect used deburred and faced
(10) perfect used deburred but not faced
(33) used rocker balls
All AMC rockers w/ balls for $125.00 (will not split). I have a "sale Pending" on these items.
Rockers - SBC 1.5 as described below:
(8) SBC Speed-Pro new in box w/ rocker balls and nuts, Shot peened.
(10) SBC Speed-Pro. Cryo'd. Perfect used.
(15) SBC grooved rocker balls included.
All SBC rockers w/ balls for $60.00.
Camshafts - All are AMC Stock Eliminator as used in D/S class w/ 1970 AMC 390 specs. All include manufacturer's box with specs. Used are in perfect condition. All cams including the new ones have been straightened (what, you actually believe they come that way from the manufacturer?). All use standard AMC bearing size & standard firing order. All were "double parkerized" and none of these cams are off the shelf standard grinds; all are custom.
1 - Bullet. New. $100.00.
2 - Lunati. Used. $75.00. Two available. Different specs on each.
3 - Comp. Used. $75.00. Two available. Different specs on each
4 - Crane. New. $100.00.
5 - Comp. used. Cryo'd. Best ever run with this cam. Ran 10.500 in D/S. $200.00. Package cam deal: $350.00 for all !
Note: I seemed to have misplaced all the cam cards, still searching! So without the cards I'm sure there is no interest...
Edited. Added more SBC / AMC pushrods and made note about camshafts. All lifters will work with .903"-.904" mopar engines, oil through pushrod. These are quality lifters and the chilled iron would be perfect for those afraid to run Schubecks.
If interested, please email direct, it's faster than PM. Or call @ 602-418-9797.
Jeff Lee 7494 D/S '70 AMX
