Old 08-20-2008, 05:22 PM   #1
RPinoski1
Default Weight Bar Tabs
Anyone have the specs. for weight bar tabs? It's not clear in the rule book. Just states (2) 1/2" bolts per 100lbs. and what the construction of the box or bar should be.
Thanks on advance
RPinoski1 is offline   Reply With Quote
Old 08-20-2008, 10:29 PM   #2
Tom Goldman
Tom Goldman's Avatar
Liked 886 Times in 238 Posts
Default Re: Weight Bar Tabs
SFI spec chassis require weight bar mounts to be a minimum of 1/8" gusseted chrome moly tabs ....A weight box would require a minimum of 2 such tabs on the frame rail or crossmember. .... It is also acceptable to bolt thru a crossmember or frame rail on non SFI spec cars, such as most S/SS classes....Tech guys usuall frown at boxes bolted thru the trunk floor. .....Tom
Old 08-21-2008, 07:12 PM   #3
RPinoski1
Thanks,
Tom
