Old 07-18-2008, 09:56 AM   #1
Chad Speier
Guest
Posts: n/a
Default Jerry Fritz '32 Bantam- 202 SB2.2 Engine
Carbon EVERYTHING!! Car has Strange PRO Carbon brakes, Digital 7 box, QuickData logger, Strange 9' Ford, This is simply one of the trickest, LW cars around. New 30 x 9 Radials. This car has less than 8 passes since NEW!!!!!!! Built for a 4 cylinder, but mods it will accept a V6-V8. Car weighs appox 700 lbs less engine/trans. Visit http://www.speierautosales.com/racecar.htm for photos. $25,000 FIRM!!!!!!!!
This engine is currently not assembled. It has appox 8 dyno pulls and 8 runs since NEW. Can be purchased assembled or ready to assemble. I'll take 1/3 of what I have in it!!! NO JUNK!
KRP Block- 55mm cam, .937 Jesel sleeves
Darin Morgan SB2.2 head (flows 430+)
Victory Ti Valves
PSI Springs
Jesel Rockers
Rebco JE Coated Pistons
NEW GRP Rods
NEW Calico Coated Bearings
NEW Total Seal Rings
Moldex Billet Crank
Charlie's sectional Oil Pan
Moroso pump
Starr Vacuum Pump
Jesel .937 Lifters
Trend Pushrods
Cam Motion Camshaft
Hogan Manifold- Reworked
Bob Book Dominator
Jesel Belt Drive
MSD front Dist
Innovators West Balancer
This engine made 460/280 first time on the dyno. I have made many changes, will make more. I'll take $13,800 and throw in a $1500 stainless steel header with a SPD cone collector!!!!!!!!!!
Chad Speier
785 625-5300
cspeier@att.net
