Old 07-17-2008, 10:57 PM   #1
castle5
Default thead sealer for aluminum heads
im going to install a set of bbc aluminum heads, im going to install studs on header and valve cover gaskets..what thread lock or sealer should i use on aluminum heads as not to tear threads out if i need to remove studs...my first aluminum heads any good tips..
castle5 is offline   Reply With Quote
