Old 07-14-2008, 07:21 PM   #1
FED 387
Liked 333 Times in 180 Posts
Question how do you check the date code on G'year slicks
What numbers do you need to check for the date code on goodyear slicks???? thanx Comp387
Old 07-14-2008, 09:12 PM   #2
Mark Callanan
Liked 64 Times in 14 Posts
Thumbs down Re: how do you check the date code on G'year slicks
Well from what I have seen if they are over 6 months old they will side wall crack
The 1st set cracked at 6 months old and they replaced them the 2nd set did the same and I went to Hoosiers and no problems
Sad huh?? .....
Mark Callanan 1027 STK
Mark Callanan is offline   Reply With Quote
Old 07-14-2008, 09:30 PM   #3
FED 387
Default Re: how do you check the date code on G'year slicks
mark--thanx for your reply but that is not the answer I am looking for--comp 387
Old 07-14-2008, 10:07 PM   #4
G Schenck
Liked 81 Times in 35 Posts
Should be a four digit code. first two numbers are the week they were made and last two are the year. Example: 1007 ........second week of March in 2007. I hope that helps.
And by the way Craig Bourgeois ran some Chile made Goodyears for three and a half years(about 350 runs) and he bought them used. Never did crack but ran out of rubber on the surface. He is still looking for the sister pair of those.
Greg
G Schenck is offline   Reply With Quote
