Old 07-14-2008, 12:38 AM   #1
Darcy Clarke
Liked 529 Times in 36 Posts
Default MSD Distributor
Hi,
Has anyone had issues with there MSD cap getting a small amount of white powdery substand on the poles of the cap. Mine will accumulate a small amount after 2 passes and then on the 3rd pass the engine will miss fire and then once cleaned will run fine. I am running a MSD billet distributor with 6AL and Super Coil same as other cars I have and never had this happen before.
Thanks
Darcy Clarke is offline   Reply With Quote
Old 07-14-2008, 01:01 AM   #2
budgetracer
Default Re: MSD Distributor
Yes I have seen this before and some have drilled a small hole some where in the cap-forgot where? Is it called Ion buildup-Sorry not a pro but know a little about this. maybe some one else can help more.
budgetracer is offline   Reply With Quote
