Old 07-08-2008, 10:33 AM   #1
furd502
Default Garage Sale
Racing Parts for Sale. (updated 7/7/08)
Ford Motorsports 9" Rear End Gears. Coated 3.89 or 4.30 $75 each
Mark Williams 9” Chromoly 1350 Yoke. $50
ATI BBC internal balance flexplate $50
Edelbrock Aluminum Water Pump Long nose 8851 New $189, Asking $100
Edelbrock Super Victor BBC intake port matched by Fast times motorworks to Brodix Heads plummed with ProRace Annular Fogger. Asking $750
March BBC Long Water Pump Serpentine setup 23010 New $299, Asking $150
Lunati ProSeries 4.25 Crank and Carrillo 6.385 Rods with CARR Bolts. New $3400, asking $1500 (will separate)
ATI Turbo 350, Low drag series with 36 element sprag New $1200, Asking $700
ATI 9" Fuel Blown Converter 4000 stall New $1000, Asking $500
CSR Composite Trans Shield T350 New $334, Asking $150
2 – 15lb Nitrous Bottles with High flow Valve New $300, Asking $150 each
2 – Chevy Turbo 350 Trans cores $60 each
MSD Billet Distributor 85551 with Cap Adapt and bronze gear New $300, asking $150
MSD Blaster 3 Coil New $40, Asking $20
MSD RPM Module 6000-8200 #8671 New $59, asking $30
Comp Cams Composite Dist Gear .500 shaft, New $112 Never used $60
NOS Bottle Heater 14164 New $140 Never used $100
NOS Cheater Fuel Solenoid 16050 New $76 Never used $50
NOS Dominator Cheater system, plate and solenoids $100
Flexalite Dual fan unit 220 New $215 asking $100
Comp Engineering Adjustable Drag Shocks, rear 1968-1987 New $40 each, asking $25 pair
Chevy 454 flywheel Never used $50
NGK Plugs –7 thru –10s $15set
Call David Furedy 412-656-4012 or Furd502@yahoo.com
furd502 is offline   Reply With Quote
