Old 06-13-2008, 01:11 PM   #1
dlv4540
Liked 2 Times in 1 Post
Default 468 street/strip longblock
I have a 1969 427 block casting number 3963512 dated C-5-9 converted to a 60 over bore and installed a #7416 LS6 crankshaft. The motor has #188 square port heads with harlan sharp roller rockers, 7/16 pushrods, howard roller camshaft 570/603, 7/16 dimple rods with 10.25 to 1 compression, 8 inch harmonic balancer and timing cover, double roller timing chain, oil pan and chrome valve covers. $3750 and this is a fresh rebuild with a couple of break in passes. I can ship if you cannot pick it up. 330-770-2517 Dennis Vugrinovich.
dlv4540 is offline   Reply With Quote
