Old 06-11-2008, 10:10 PM   #1
willys-gasser
willys-gasser's Avatar
Default 1941 fiberglass willys coupe
For Sale
41 Willys
Fiberglass
Engine: 1971 402 Big Block Chevy With Ported Heads,with Stainless 2.19 Intake And 1.88 Exhaust Valves, 7 Qt. Moroso Chrome Oil Pan, Aluminum Intake, 750 Holley Dp, Accell Dist,moroso Electric Water Pump, Chrome Sfi Ballencer, Sfi Flex-plate, Custom Built Tuned Race Headers (coated),finned Aluminum Valve Covers,total Seal Rings, Hi-volume Oil Pump,comp Cam,comp Valve Springs,harland Sharp Roller Rockers, All Arp Fastners.
Transmission: Action Racing Turbo 400 With Manual Valve Body.b&m Sfi Trans Sheild,hurst Quarter Stick Shifter With Console And Power Switches.
Frame; Powder Coated 2x3 Box Tube Custom Frame, With 8-point Chrome-moly Cage, 2" Chromed Chrome-moly Straight Tube Axle, Chromed Posey Leaf Springs, Stainless Steel Steering Linkage, Vega Steering Box,chrome Moly Tube Steering Column, Disc Brakes,90-10 Front Shocks, Chromed Ladder Bars And Diagonal Link, Powder Coated 9" Ford Rear End , With Nodular Center Section, 4.56 Gears , Strange Spool, 33 Spline Strange Axles, Drum Brakes.3 ½ Inch Stainless Steel Tube Rear Bumper.
Body: Straight, Thick, Hand Laid Fiberglass Body,lite-weight Tilt One Peice Willys-works Nose,willys-works Lite-weight Trunk,willys-works Lite-weight Rear Fenders. Doors Latched And Hinged With Polished Stainless Hinges.trunk Dzus Fastened With Stock Chrome Handle.
American Racing 5- Spoke Wheels With M/t 26x7.50x15 Fronts, 31x10.50x15 M/t Slicks,58 Ford Grille, Swc Style Headlamps. Aluminum Radiator, Electric Fan, Jaz Overflow Bottle.
New Wiring Harness, Power Window Regulators, Aluminum Racing Seat.
Parts Inclided With Car;
New Gasser Style Headlamp Kit
1958 Ford Aluminum Grille
Electric Cooling Fan
Newhi-torque Mini Starter
Holley 750 Double Pumper Carb
Accell Distributor
New Custom Built Tuned Fenderwell Headers (coated)
New Inside And Outside Chrome Willys Door Handles
Transmission Cooler
New E-z Wire Wiring Harness
New Power Window Regulators
New Hurst Quarter Stick Shifter
8 Gallon Fuel Cell
New Battery Tray
Battery Disconnect Switch
New 4-piece Bolt Together (street Weight) Fiberglass Nose With Opening Hood
New (street Weight) Rear Fenders
New (street Weight) Trunk Lid
New 3 ½ Inch Tube Stainless Steel Rear Bumper
This Car Is Not Finished (90%).
Please Email Or Call Me At mb3660@comcast.net 603-742-4896
$ 32000,00 Or Best Offer
Avatar Is A Current Picture Of This Car...
willys-gasser is offline   Reply With Quote
