Liked 5 Times in 3 Posts
Where should I start with jetting on my 4 jet 283 super stocker? sea level. Carb is currently been dialed in for denver and I have no clue where to start. Not going on dyno so any advice would be great.
Try 64 in the front and 66 in the rear as a starting point.. Are you using the lower air door? If so is it operable or locked open?
Chuck OOPS! should have read the post closer - I ran a Stocker. I have no business commenting on a Super Stocker. CP Last edited by Chuck Porter; 06-06-2008 at 01:13 AM. |
Liked 1,436 Times in 299 Posts
Try talking to Dean Oliver. He is the master when it comes to SS and Stock 4GC's. I think it will be important to understand who prepped the carb or what has been done among other things. I run a stocker and generally stockers are jetted richer than SSers with the 4GCs. Hard to really answer without more specific info.
http://www.deanoscarbs.com/
James Schaechter 3163 STK |
I moved from Colorado Springs to Oklahoma and when I arrived in Colorado i talked to some BB impala guys and all they did was put more timing in my motor. So when I got back I took some tming out and ran the same Jetting.
