Old 06-02-2008, 06:52 PM   #1
dragster2006
dragster2006's Avatar
Unhappy Roll Bars
Im currently building a 97' Cavalier to race in the super street class and i was wondering whats mandatory for nhra certification... is it ok to run a 6 point cage or does it have to be 8 point and up? The other question was if its alright to weld the roll bar with a mig welder instead of a tig welder... does it really matter? or are you suppost to use mig on it...? PLEASE HELP ME!!!! HA HA HA!!!! :-)
dragster2006 is offline   Reply With Quote
Old 06-02-2008, 11:11 PM   #2
voltdr
Liked 100 Times in 51 Posts
Default Re: Roll Bars
Depends on the speed you will run. If over 135 you need to follow the rules for SG. Then it also depends on the ET of the car. Different rules for 8.50 or 7.50 etc. Also you can only MIG mild steel. If using CM it must be TIGged.
voltdr is offline   Reply With Quote
Old 06-02-2008, 11:58 PM   #3
dragster2006
yeah the car should be running around 120-130ish cause its running on the 10.90 standard... i believe the roll bar kit is just mild steel so then i should be ok... its the jegs roll bar kit...
Old 06-03-2008, 07:52 AM   #4
Tim Irwin
Put a cage in it that will certify. It will increase the value of the car if you ever decide to sell it.
Tim Irwin is offline   Reply With Quote
Old 06-03-2008, 07:56 AM   #5
Joe Pinkston
Joe Pinkston's Avatar
Thumbs up Re: Roll Bars
If the car retains the stock fire wall and floor, and does not exceed 135 MPH then the 6 point bar is acceptable.
Joe Pinkston 2155 S/ST
Joe Pinkston is offline   Reply With Quote
Old 06-03-2008, 08:14 AM   #6
H.A.A.C. Racing
H.A.A.C. Racing's Avatar
Just make sure you position the roll bar in a place where it can be added onto for the future. If you decide you want to go faster, you wont want to cut out what you already have. Under 135, 6 point and mig weld is o.k. on mild steal
H.A.A.C. Racing is offline   Reply With Quote
Old 06-03-2008, 11:12 AM   #7
Bob Verwold
Bob Verwold's Avatar
I agree.........If you have ever seen a car on the roof, and everything is ground down to the cage you'll be more than glad you went the extra mile.........
Bob Verwold is offline   Reply With Quote
Old 06-03-2008, 04:07 PM   #8
dragster2006
Talking Re: Roll Bars
Ok... Well from what you guys have told me... you've convinced me to buy the 8 point kit lol thanks for the help! if i have any other questions in the future i'll message you guys! thanks!
