Old 05-29-2008, 02:47 PM   #1
RussellinNC
Thumbs up 1967 Camaro RS Stocker in NC
1967 Camaro Real RS,Street/drag car.(Last raced with the Classic Gear Jammers) Clear title,No Engine or trans,(Had a small block and Jerico 4-speed)4 wheel disc WILWOOD brakes,Braided Brake lines,not narrowed 12-bolt rear with moser axles,spool,4:88 Pro Gear,Braced Aluminum rear end cover,Calvert Rear Split leaf springs and Cal-Trac bars,Frame connectors,Dual holly blue pumps, FRAM filter for each pump,fuel cell,Braided fuel lines front to rear,MSD ignition,Full factory interior with 6 point roll bar,GM cowl hood,Comes with another 4 inch cowl fiberglass pin on hood,Small block headers,1 chamber flowmasters,pipes and H pipe,Driveshaft,Rally Wheels,AutoMeter Gauges,Monster tach with Large pro shift light,Etc Etc...Drop in a small block and 4-speed and go play $10,000 FIRM
I have the original Gas tank,Heater box,Heater controls,etc.
Russell Patterson
704-682-3057 Statesville,NC
Ponattack1@aol.com for pics
RussellinNC is offline   Reply With Quote
