Liked 68 Times in 41 Posts
What air pressure should I run in hoosier radial and/or goodyear radial.E/sa dodge demon. 3310 lbs. runs .7 under.it's a new car to me.any help would be great.
Liked 1,593 Times in 583 Posts
Liked 238 Times in 78 Posts
I agree, start at 20 lbs. At a good track, with that much wieght, you should be able to run 22-24 lbs of air pressure. Each pound that you can put into a radial (without spinning) is usually worth .005-.008.
Dean |
20 lbs always works best on my '71 Duster E/SA @ 3310#. Good luck with the new car, hopefully we'll cross paths sometime, maybe the North American Nationals at Epping.
George Mirza |
thanks for the info.see how it works on the weekend. I will be at Epping. see you there.
KELLY MACKAY Last edited by dartman; 05-28-2008 at 06:29 AM. |
