Liked 5 Times in 3 Posts
my 04 mustang has a headlight that is "foggy" how can I fix it?
Liked 4 Times in 2 Posts
Probably got some moisture up inside it Greg. Get it dried out, and might have to silicone seal it. I know this is what we have had to do before on the Firebird tail lights.
Lee Norton - N229 STK IHRA H/FIA - NHRA O/SA RacerTees.com |
Try your local hobby shop for some plastic polish , Tamiya Finish Polish if they have it.
Bud Lefevre 3075 STK IHRA World Record Holder |
Greg,
Spend some of the money your wife saved on gas (with the Mini) and get a new one...................HA HA |
Liked 333 Times in 180 Posts
If the cloudiness is on the outside try TOOTHPASTE--It will do a great job too---takes a little while but just put it on and rub/buff it with a damp---NOT SOAKING WET cloth---any brand of toothpaste will work just use the stuff in a tube----Comp 387
Liked 51 Times in 14 Posts
Greg,
If i'ts on the outside you can recondition it with a headlamp reconditioning kit. You can most likely find one online. The brand we use is from Bright Solutions. Jeff Ross |
I just fixed the same problem on my Lexus and used Meguiar's PlastX. It is a clear plastic cleaner and polish; in a nut shell, it restored them better than new. It was very easy to use and did both front headlight lenses in 5 minutes. It worked so good that although they are red, I did the rear lenses too.
http://www.meguiars.com/?clear-plast...Cleaner-Polish |
Liked 33 Times in 17 Posts
"Flitz" This stuff works pretty well and is available at most auto parts.
guess I should have said it's on the inside...I hit a deer with the car in Nov.06 & both headlight were replaced then. the one on the drivers side has...fog,dew,water? inside it? Thanks for the help guys
Greg,
Was the light oem or aftermarket. If thr repair was an insurance claim you may be able to go back to the repair shop and speak to them about the problem. Our aftermarket suppliers would warranty such a problem. OEM replacement is usually more difficult but most of the time can be warrantied as well. Jeff |
