Old 05-17-2008, 07:51 AM   #1
td1506
td1506's Avatar
Default Opel gt
Car has 2x3 frame rails .The rest of the car cage is chrome moly Have some extra stuff that will go with the car. Car cover , tire covers, ft. end stand ,custom BBC headers.All electronic's Dedenbear SCO1 with timers,shift timer is a Dedenbear set up for rpm or time, play back tack, all painless wiring.Slicks have about 10 passes on them.Shroud parachute is new .Strange spindle mount ft. struts. Rear coil over 's ,springs are new last year , four link with a wishbone stablizer, Quartermax antiroll bar, early Olds rear end with 4:10 gears.Ft. end is one piece fiberglass, rest of the body is steel. Car will fit a MEDIUM size driver.Car weights 2150 with a BBC without driver.Ran the car in IHRA super rod .All certs. have run out. Car is located in the Rochester New York area.
Nice nastalgia car.
td1506 is offline   Reply With Quote
