Old 04-28-2008, 10:42 PM   #1
willys-gasser
willys-gasser's Avatar
Default 1941 fiberglass willys coupe
I WAS BUILDING THIS CAR AS A NOSTALGIA GASSER.COULD EASILY BE CONVERTED TO STREET ROD. (NOSE-UP STYLE) CAR HAS A 71 402 BBC WITH PORTED HEADS,WITH STAINLESS 2.19 INTAKE AND 1.88 EXHAUST VALVES, 7 QT. MOROSO CHROME OIL PAN, ALUMINUM INTAKE, 750 HOLLEY DP, ACCELL DIST,MOROSO ELECTRIC WATER PUMP, CHROME SFI BALLENCER, SFI FLEX-PLATE, CUSTOM BUILT TUNED RACE HEADERS (COATED),FINNED ALUMINUM VALVE COVERS,TOTAL SEAL RINGS, HI-VOLUME OIL PUMP,COMP CAM,COMP VALVE SPRINGS,HARLAND SHARP ROLLER ROCKERS, ALL ARP FASTNERS. ACTION RACING TURBO 400 WITH MANUAL VALVE BODY.B&M SFI TRANS SHEILD,HURST QUARTER STICK SHIFTER WITH CONSOLE AND POWER SWITCHES.
FRAME; POWDER COATED 2X3 BOX TUBE CUSTOM FRAME, WITH 8-POINT CHROME-MOLY CAGE, 2" CHROMED CHROME-MOLY STRAIGHT TUBE AXLE, CHROMED POSEY LEAF SPRINGS, STAINLESS STEERING LINKAGE, VEGA BOX,CHROME MOLY TUBE STEERING COLUMN, DISC BRAKES,90-10 FRONT SHOCKS, CHROMED LADDER BARS AND DIAGONAL LINK, POWDER COATED 9" FORD REAR END , WITH NODULAR CENTER SECTION, 4.56 GEARS , STRANGE SPOOL, 33 SPLINE STRANGE AXLES, DRUM BRAKES. STAINLESS TUBE REAR BUMPER.
BODY: STRAIGHT, THICK, HAND LAID FIBERGLASS BODY,LITE-WEIGHT TILT ONE PEICE WILLYS-WORKS NOSE, 4-PEICE STREET WEIGHT NOSE,WILLYS-WORKS LITE-WEIGHT TRUNK, STREET WEIGHT TRUNK,WILLYS-WORKS LITE-WEIGHT REAR FENDERS, STREET WEIGHT REAR FENDERS. DOORS LATCHED AND HINGED WITH POLISHED STAINLESS HINGES.TRUNK DZUS FASTENED WITH STOCK CHROME HANDLE.
AMERICAN RACING 5- SPOKE WHEELS WITH M/T 26X7.50X15 FRONTS, 31X10.50X15 M/T SLICKS,58 FORD GRILLE, SWC STYLE HEADLAMPS. ALUMINUM RADIATOR, TWIN ELECTRIC FANS, JAZ OVERFLOW BOTTLE. NEW WIRING HARNESS, POWER WINDOW REGULATORS, ALUMINUM RACING SEAT. I HAVE PROBABLY FORGOTTEN SOME OTHER PARTS.
THIS CAR IS NOT FINISHED (90%). PARTS NEEDED TO COMPLETE , TORQUE CONVERTER,DRIVE SHAFT, GLASS,REAR SHOCKS. ASKING $30,000 OR TRADE FOR A GM STOCK ELIMINATOR DRAG CAR... I HAVE MORE THAN THAT INVESTED JUST IN PARTS......
PLEASE EMAIL OR CALL ME AT MB3660@COMCAST.NET 603-742-4896 AFTER 6:00 PM EST.
THANKS KIRK
PICTURES AVAILABLE.....
willys-gasser is offline   Reply With Quote
