Old 04-25-2008, 10:10 AM   #1
Rick496D
Default Digital Tire Gauge
Has anyone used the "Quick Car" digital gauge. How accurate is it? What are some good ones?
Rick496D is offline   Reply With Quote
Old 04-25-2008, 11:36 AM   #2
SlickVic
SlickVic's Avatar
Default Re: Digital Tire Gauge
I use the jegs one.* Its lighted, re zero, and will work on front and back tires.* .1 incraments.* I thnk they go for about 80$.
87 Cavalier, 92 Corvette, 72 Nova, 68 Firebird
SlickVic is offline   Reply With Quote
Old 04-26-2008, 09:57 AM   #3
CPOlesen
You will get different readings with the best tire gauge of the same brand. The key is get a good one and base your settings one the one you pick. Also pressure gages work best in the middle of the operating range. Example if you going to run 15 psi get a 30 psi gauge..
CPOlesen is offline   Reply With Quote
