Old 04-21-2008, 03:57 PM   #1
Smitty
Smitty's Avatar
Default 351 Cleveland Heads For Sale
2 sets of 351 Cleveland Heads for sale:
-Closed Chamber appear to be late 70 or early 71 castings matching pair, uncut virgin heads, good set for
a stocker or SS.
$275 plus shipping
-Open Chamber 2.19/1.71 valve heads; 75cc chambers, stock exhaust ports, mildy filled intake ports
(241cc) already has screw in studs installed, can be bought with springs that will support up to
.650 lift cam, good base for SS heads.
$350 plus shipping
-I also have other assorted Cleveland Parts, fresh .030 block that has been filled, (2) .010/.010 4MA
cranks, 1 set of Eagle Rods with dome pistons for open chamber heads, and a stock set of Cleveland
rods that have polished beams and ARP stud bolts installed with dome pistons for closed chamber head
combo. Also an Ultra Dyne Solid Roller Cam that is 287/293 @ .050 and is .626/.626' lift.
Contact Terrance Smith at 910-987-2227 or 813-569-5787
email boss358c@yahoo.com
Smitty is offline   Reply With Quote
Old 04-21-2008, 07:52 PM   #2
nikki379asg
Send a message via Yahoo to nikki379asg
Default Re: 351 Cleveland Heads For Sale
is the block 2 bolt or 4 bolt. is it std or 30 over and has it been decked. is the crank stock ford for std. or are they steel cranks std?
nikki379asg is offline   Reply With Quote
Old 04-21-2008, 10:47 PM   #3
Smitty
Smitty's Avatar
The block is a 72 date code block, 2 bolt main caps with ARP studs, bored .030 and has not been decked. Crank is a .010/.010 and is a 4MA nodular.
