Old 04-18-2008, 12:25 PM   #1
et134R
Default E85 set-up questions
So, for those that have converted to E85 that are running injection, What kind of jet/ tune-up changes did you make? Does anyone know were to go to get info on this?
I have a 96 Ed Quay Dragster (1830 lbs.) that currently runs 7.90s @ 170. mph in the quarter (about 700 horsepower est.) on Methonal.
My car runs a a Rons Flying Toilet Injection system. This is a constant flow mechanical injection system w/ a Waterman .500 pump that turns 4.85 gal per min. On Methonal I'm running .31 nozzle jets and a .70 main jet with a 6 lbs. relief spring.
I am very interested in converting to E85.
Is anyone one here currently running a similar set-up?
Can anyone give me an idea of were to start ?
Can anyone put me in contact with someone that can help me with set-up?
What kinds of temps should I expect on an EGT system if I'm running 32 deg. timing?
Should I change the timing in my car on E85?
What type of water temp. gains should I expect to see during a pass on E85?
What type of Air/ Fuel Ratio numbers should I see on my O2 gauge?
Is there anything else I should know about E85 before running it?
Your help will be greatly appreciated. Thank you in advance.
Raymond Keown
Precision Performance Racing
A2Z Racing
NRG Swimming
Levittown, Pa. 19056
rkeown66@yahoo.com
215-715-4290
et134R is offline   Reply With Quote
Old 04-18-2008, 06:38 PM   #2
Rob Petrie E395
Liked 216 Times in 77 Posts
Default Re: E85 set-up questions
I am by no way an expert on E85, I know alot of guys are going to it but I thought I would post a bit about what was said about it at the World drag expo this year. VP racing fuels had a guy there giving a seminar about race fuels. somebody asked about E85 the speaker from VP spoke about it for several minutes including why they are not currently getting into the market for racing pourposes. The thing I remember most about what he had to say was how E85 is not consistant from batch to batch. he said that E85 has to be at least 85% ethanol but can be higher meaning that one day when you buy it you may get 85% ethanol but the next it may be 88% or more which could really screw up consistancy in a race car. He went on to say that if they were to start mixing it to exact specs like they do race gas the cost benifits would go away compared to methanol. I really wish I could remember his name he was a great speaker and really informative I can tell you that this seminar was packed. you might want to call VP midwest and see if they can put you in touch with him as there were several other reasons that he also stated. I know they are a Racing Fuel company so they are biased towards using their products but what he had to say did make sense to me. Hope this helps even though its not exactly what you were looking for.
Rob Petrie
