Old 04-02-2008, 08:16 PM   #1
Camaro Nut
Default Moser 12 bolt ???
Are the after market 12 bolts for a 84-92 the same length as a 93-02 F Body ?
Camaro Nut is offline   Reply With Quote
Old 04-02-2008, 09:33 PM   #2
Chad Rhodes
Default Re: Moser 12 bolt ???
no, but i believe alot of 4th gen cars are running 3rd gen rears, legal or not
Chad Rhodes 2113 I/SA
Old 04-02-2008, 10:58 PM   #3
G Schenck
Liked 81 Times in 35 Posts
Nine out of ten rear ends are shorter than stock in the 4th gen cars.Mainly because of wheel off sets. Bogarts make the only wheel for a stock rear end.
Greg
G Schenck is offline   Reply With Quote
Old 04-03-2008, 12:02 AM   #4
LNorton
LNorton's Avatar
Liked 4 Times in 2 Posts
Greg, I have a weld wheel under my 4th gen with a stock rear. I can get it in an 8'' and 10'' as well.
Lee Norton - N229 STK
IHRA H/FIA - NHRA O/SA
RacerTees.com
LNorton is offline   Reply With Quote
Old 04-03-2008, 08:51 AM   #5
Rob Petrie E395
Liked 216 Times in 77 Posts
Moser sells a rear for the fourth gen that can use the stock wheels. If you want racing wheels with a stock length rear you need a 15X10 with a 7.5 backspace Weld draglites/prostars make this wheel. When I first got my car back in 95 this is what I had on the back. When that rear broke not much later I got the Moser and it was stock length (I have since narrowed it to allow more of a wheel selection). My understanding is that they are the same lenghth except for what is called the Austrailian 9 bolt which you want to stay away from as there is currently no aftermarket gears/parts for. I am pretty sure I am correct but double check me as always I do somtimes make mistakes. Hope this helps
