Old 04-01-2008, 07:05 PM   #1
Camaro Nut
Default Lt 1 ???
Does any body know of any body running a FACTORY stock short block in NHRA stock elimanator. I am thinking about trying it for the first year. I allready picked up a nice set of heads and a cam done by Bud Rowe. So I am thinking about just doing the heads and cam and then have a brand new motor done for next year .I plan on doing headers,12 bolt raer,all susspension work ETC. and just get the car out and see if I could run under the index. Any help and advice would be grate Thanks
Camaro Nut is offline   Reply With Quote
Old 04-02-2008, 08:15 AM   #2
Rich Biebel
Rich Biebel's Avatar
Liked 557 Times in 217 Posts
Default Re: Lt 1 ???
I met a racer who had an LT-1 Camaro and he said he had a stock shortblock with just a cam and he did the heads. He was able to run under the index by a few tenths running in C/FIA in decent air. I think he broke it after some runs though. I helped him correct a problem with his Accel DFI.
Rich Biebel
S/C 1479
Stock 147R
Old 04-02-2008, 08:03 PM   #3
Camaro Nut
What is the weak link on a stock short block? Is it the rod?
Old 04-02-2008, 08:34 PM   #4
If it has powdered rods, yes, the rod is the weak link. That doesn't mean that's the first, or only thing that will fail. But I'd replace the rods if I was going to race it.
Old 04-03-2008, 08:06 PM   #5
Camaro Nut
Do you think if I was to take a stock short block and install a good set of rods in it I would be able to get away with running it like that for about 100 runs. I am just trying to get the car out and get some runs on it to see if the susspension works and then have a good bullet built.
Old 04-03-2008, 08:17 PM   #6
Woodro Josey
Liked 3 Times in 1 Post
Alan is correct about the rods, and while it is down, get someone to hone it with torque plates. Also, the Optispark is also a weak link, go ahead and purchase the MSD Rotor and Cap kit and this should take care of that problem!
Woodro Josey 2002 STK
Woodro Josey is offline   Reply With Quote
Old 04-03-2008, 08:33 PM   #7
That's a thought Woodro. If you take it apart, to replace the rods, you'll have to balance it as well. But if you'll hone it with torque plates (have this done by a shop capable of doing RACE work) and get a ring package (made for Stock Eliminator) from some one like Total Seal, Childs and Albert, or Ackerly and Childs, and set the deck height, you'll get a good return on your money. Woodro can probably steer you right on a ring pack. His little LT1 whips up on my 427!
Old 04-03-2008, 09:36 PM   #8
Originally Posted by 1664SSJA View Post
With all that being done his "stock bottom end" is only pistons away from a good piece.
Go the distance!
Not really. I'd want to pour it and bore it before I'd invest in new pistons, and it'd also get align honed. It'd need a fully prepped crank (blueprint stroked and indexed) as well. A lot more money and work.
Old 04-04-2008, 05:29 AM   #9
Glenn Briglio
Glenn Briglio's Avatar
Liked 986 Times in 314 Posts
We've done it both ways, using a stock short block and a "done" short block. Give me a call. Glenn.(516) 599-7182.
Last edited by Glenn Briglio; 04-04-2008 at 05:31 AM. Reason: forgot telephone number
Old 04-04-2008, 06:51 AM   #10
Chuck Garey
Liked 10 Times in 7 Posts
If your near Virginia I have a short block ready to assemble, coated venolia's, eagle rods, bearings, already bored, decked, etc.
$2,000.00
Chuck Garey is offline   Reply With Quote
