Old 03-31-2008, 08:55 PM   #1
Wilderacing
Default Front tire size
I am building a corvette roadster and was wondering what front tire size most guys were running on there super gas cars.
Wilderacing is offline   Reply With Quote
Old 04-08-2008, 10:33 AM   #2
Jason Oldfield
Jason Oldfield's Avatar
Liked 10 Times in 4 Posts
Send a message via AIM to Jason Oldfield Send a message via MSN to Jason Oldfield Send a message via Yahoo to Jason Oldfield
Default Re: Front tire size
I can't believe you never got a response to this...
Mine are either the 22" or 23". I can't remember for certain. I don't know if anybody has any particular reasoning for NOT running as short a tire as possible, but it would seem to me that unless ground clearance was an issue that you'd want to run the shortest tire possible for the least amount of rollout.
Jason Oldfield
S/G & S/St 1838
Jason Oldfield is offline   Reply With Quote
Old 04-08-2008, 03:41 PM   #3
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
23" or 24" should work fine. .....22"tires are really small,and could cause clearance problems for a diaper........Also, if you are building it correctly,The car will hit the tree without a tiny tire. ........You'll end up with a ton of numbers in the delay box with that short a tire....... Tom
